/[TIS-4000 Rel T60]/Tornado2/platform/Makefile.config
Log of /Tornado2/platform/Makefile.config
Tue Nov 28 17:27:37 2000 UTC (22 years ago) by tis4000
Changes since 1.1: +10 -10 lines
Removed platform.o mv147.o mv167.o x486.0 and weatchdog.o. - szostak
Fri Apr 21 17:36:24 2000 UTC (22 years, 7 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.28
