Log of /Tornado2/rec/Makefile.config
Parent Directory
Revision Log
Revision Graph
Revision
1.2 -
view)
annotate)
[select for diffs]
Tue Jun 6 11:37:54 2000 UTC
(22 years, 7 months ago)
by
tis4000
Branch:
MAIN
Changes since
1.1: +3 -3 lines
Diff to
previous 1.1
Add recUdds and uddsTools to the build. - Steel
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
