/[TIS-4000 Rel T60]/Tornado2/rec/Makefile.config
Log of /Tornado2/rec/Makefile.config
Mon Jun 12 18:12:03 2000 UTC (22 years, 5 months ago) by tis4000
removed uddsTool as seperate target, now part of recSup - Steel
Tue Jun 6 11:37:54 2000 UTC (22 years, 6 months ago) by tis4000
Add recUdds and uddsTools to the build. - Steel
Fri Apr 21 17:36:25 2000 UTC (22 years, 7 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.28
