/[TIS-4000 Rel T60]/Tornado2/rec/Makefile.target
Log of /Tornado2/rec/Makefile.target
Mon Jun 12 18:12:37 2000 UTC (23 years ago) by tis4000
Changes since 1.3: +0 -2 lines
removed uddsTool as seperate target, now part of recSup - Steel
Revision 1.3 - (view) (annotate) - [selected]
Tue Jun 6 11:37:54 2000 UTC (23 years ago) by tis4000
Add recUdds and uddsTools to the build. - Steel
Tue May 16 19:56:32 2000 UTC (23 years ago) by tis4000
Changes since 1.1: +0 -1 lines
removed udds, not ready yet - Steel
Fri Apr 21 17:36:25 2000 UTC (23 years, 1 month ago) by tis4000
Branch point for: HIA
Diff to selected 1.3
Powered by ViewVC 1.1.28
