/[TIS-4000 Rel T60]/Tornado2/redund/Makefile
Contents of /Tornado2/redund/Makefile
Fri Apr 21 17:36:25 2000 UTC (22 years, 11 months ago) by tis4000
Branch: HIA, MAIN
Setup Initial Baseline
1 # Define the local target base directory
2 CUR = redund
3
4 # Define the release root directory
5 TOP = ../../..
6
7 # Define the Tornado install directory and host type
8 WIND_BASE = c:/Tornado2
9 WIND_HOST_TYPE = x86-win32
10
11 # define the base location of the standard makefile
12 MAKE_TOP = $(TOP)\Tornado2\stdMakefiles
13
14 # TORNADO Makefile strategy-
15 # perform make with the -C <dir> for each valid target
16 # Each target subdir will select correct Make include environment
17 # target names hardcoded for now
18
19 default:: M30 X486
20
21 M30 :
22 mkdir M30
23 X486 :
24 mkdir X486
25
26 M30_O:
27 make -C ./M30 -f $(MAKE_TOP)/Makefile user_target DST=M30 CUR=$(CUR) CPU=MC68040
28
29 X486_O:
30 make -C ./X486 -f $(MAKE_TOP)/Makefile user_target DST=X486 CUR=$(CUR) CPU=I80486
31
Powered by ViewVC 1.1.28
