/[TIS-4000 Rel T60]/Tornado2/sstools/MAKEFILE
Contents of /Tornado2/sstools/MAKEFILE
Fri Apr 21 17:36:28 2000 UTC (22 years, 7 months ago) by tis4000
Branch: HIA, MAIN
Setup Initial Baseline
1 # Define the local target base directory
2 CUR = sstools
3
4 # Define the release root directory
5 TOP = ../../..
6
7 # define the base location of the standard makefile
8 MAKE_TOP = $(TOP)\Tornado2\stdMakefiles
9
10 # TORNADO Makefile strategy-
11 # perform make with the -C <dir> for each valid target
12 # Each target subdir will select correct Make include environment
13 # target names hardcoded for now
14
15 default:: M30 X486
16
17 M30 :
18 mkdir M30
19 X486 :
20 mkdir X486
21
22 M30_O:
23 make -C ./M30 -f $(MAKE_TOP)/Makefile user_target DST=M30 CUR=$(CUR) CPU=MC68040
24
25 X486_O:
26 make -C ./X486 -f $(MAKE_TOP)/Makefile user_target DST=X486 CUR=$(CUR) CPU=I80486
27
Powered by ViewVC 1.1.28
