/[TIS-4000 Rel T60]/Tornado2/vxext/Makefile
Log of /Tornado2/vxext/Makefile
Wed May 17 20:04:32 2000 UTC (23 years, 4 months ago) by tis4000
Changes since 1.1: +0 -4 lines
Removed default that tried to make the contents of X486 & M30. - Szostak
Wed May 17 19:18:44 2000 UTC (23 years, 4 months ago) by tis4000
Required for hwicc830. - Szostak
Powered by ViewVC 1.1.30
