/[TIS-4000 Rel T60]/scripts/buildsnl
Log of /scripts/buildsnl
Tue Apr 10 18:56:32 2001 UTC (22 years, 5 months ago) by tis4000
CVS Tags: Duluth_baseline, HEAD, SPR801
Changes since 1.2: +5 -9 lines
SPR 801
Do not reverence /usr/include. - zigalov
Tue Aug 15 17:40:17 2000 UTC (23 years, 1 month ago) by tis4000
CVS Tags: LMC_baseline
Added M30 to compiler path, removed -B switch from gcc command, gcc whines that it is not used - Steel
Mon Apr 24 14:46:54 2000 UTC (23 years, 5 months ago) by tis4000
Files added from t55. - NDalesio
Powered by ViewVC 1.1.30
