/[TIS-4000 Rel T60]/scripts/installTis4000
Log of /scripts/installTis4000
Revision 1.9 - (view) (annotate) - [select for diffs]
Mon Feb 5 21:23:32 2001 UTC (22 years, 7 months ago) by tis4000
CVS Tags: Duluth_baseline, HEAD
Changes since 1.8: +7 -18 lines
Remove modification of limitorque. - ncd
Revision 1.8 - (view) (annotate) - [select for diffs]
Fri Jan 12 14:59:28 2001 UTC (22 years, 8 months ago) by tis4000
CVS Tags: LMC_baseline
Changes since 1.7: +25 -25 lines
Change directory path of copy. Add modification of limitorque. - ndalesio
Revision 1.7 - (view) (annotate) - [select for diffs]
Thu Jan 4 14:45:45 2001 UTC (22 years, 8 months ago) by tis4000
Changes since 1.6: +228 -104 lines
Add prompts for individual directory replacement. - ndalesio
Revision 1.6 - (view) (annotate) - [select for diffs]
Fri Sep 8 13:22:45 2000 UTC (23 years ago) by tis4000
Commented out copy of .usr. - NDalesio
Revision 1.5 - (view) (annotate) - [select for diffs]
Wed Jun 28 16:04:09 2000 UTC (23 years, 3 months ago) by tis4000
Changes since 1.4: +12 -0 lines
Added chown and chgrp of lock directories. - NDalesio
Wed Jun 7 18:46:56 2000 UTC (23 years, 3 months ago) by tis4000
Changes since 1.3: +6 -6 lines
Changed user message to eliminate obsolete variable. Prompted user for $targetIOC. Removed vuconfig.* links. Corrected apxOracleDispatch. - NDalesio
Tue Jun 6 20:21:14 2000 UTC (23 years, 3 months ago) by tis4000
Changes since 1.2: +2 -5 lines
Eliminated dm and edd links. Eliminated /axhome/apxDispatch and /axhome/apxfunc.h links. Added apxOracleDispatch and save_report2.am links. - NDalesio
Fri Jun 2 20:21:24 2000 UTC (23 years, 3 months ago) by tis4000
Changes since 1.1: +25 -9 lines
Changed comment from t55 to t60. Added tisTime. Corrected path of compilers and added more compilers. Added java tools. - NDalesio
Mon Apr 24 14:50:00 2000 UTC (23 years, 5 months ago) by tis4000
File copied from t55. - NDalesio
Powered by ViewVC 1.1.30
