/[TIS-4000 Rel T60]/scripts/start_TIS
Log of /scripts/start_TIS
Fri Sep 1 11:34:56 2000 UTC (23 years ago) by tis4000
Changes since 1.2: +12 -39 lines
Start tisTime instead of timeServer. Don't need to be root. Don't need call to ndd command done in rc.*** files. Don't need to su to tis4000. - Steel
Tue Aug 15 13:44:53 2000 UTC (23 years, 1 month ago) by tis4000
Replaced timeServer with tisTime and a NOTE that the documentation needs
to be read because of the command line arguments
Steel
Mon Nov 29 15:10:56 1999 UTC (23 years, 10 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
