/[TIS-4000 Rel T60]/scripts/starttis4000
Log of /scripts/starttis4000
Fri Sep 1 11:36:57 2000 UTC (23 years, 1 month ago) by tis4000
Changes since 1.2: +72 -61 lines
Added call to startJava. Documented calls. - Steel
Tue Aug 15 13:03:17 2000 UTC (23 years, 1 month ago) by tis4000
Changes since 1.1: +18 -0 lines
Added reindexing of alarmlog and op_trak
Added (comment out) start ping program
Steel
Mon Nov 29 15:10:56 1999 UTC (23 years, 10 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
