Log of /scripts/stop_TIS
Parent Directory
Revision Log
Revision Graph
Revision
1.4 -
view)
annotate)
[select for diffs]
Mon Sep 25 14:49:54 2000 UTC
(23 years ago)
by
tis4000
Branch:
MAIN
CVS Tags:
SPR635
Changes since
1.3: +4 -0 lines
Diff to
previous 1.3
SPR 635
Needs to make sure everyone is logged out of the tis4000 system. Added a line that will remove all files from /tis4000/operators/logins. - Steel
Revision
1.3 -
view)
annotate)
[select for diffs]
Fri Sep 1 11:36:02 2000 UTC
(23 years ago)
by
tis4000
Branch:
MAIN
Changes since
1.2: +2 -12 lines
Diff to
previous 1.2
Don't need to be root. Added many more gui programs and processes to look for. Added stopJava call. - Steel
Revision
1.2 -
view)
annotate)
[select for diffs]
Tue Aug 15 12:51:10 2000 UTC
(23 years, 1 month ago)
by
tis4000
Branch:
MAIN
Changes since
1.1: +15 -11 lines
Diff to
previous 1.1
Comment out need to be root
Added processes to list:
tisTime
LogReport
Added call to stopJava before call to stop otehr process
Steel
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
