/[TIS-4000 Rel T60]/scripts/tistasksfiles
Log of /scripts/tistasksfiles
Revision 1.20 - (view) (annotate) - [select for diffs]
Fri Sep 14 14:58:16 2001 UTC (22 years ago) by tis4000
CVS Tags: Duluth_baseline, HEAD
Changes since 1.19: +6 -6 lines
Diff to previous 1.19
AddE2DBGen to distribution. - ncd
Revision 1.19 - (view) (annotate) - [select for diffs]
Mon Jul 16 18:54:22 2001 UTC (22 years, 2 months ago) by tis4000
Changes since 1.18: +1 -0 lines
Diff to previous 1.18
Add EZModicon driver. - ncd
Revision 1.18 - (view) (annotate) - [select for diffs]
Tue Jul 10 18:28:55 2001 UTC (22 years, 2 months ago) by tis4000
Changes since 1.17: +2 -0 lines
Diff to previous 1.17
Add Oracle SnapEdit files to distribution. - ncd
Revision 1.17 - (view) (annotate) - [select for diffs]
Fri May 11 14:58:12 2001 UTC (22 years, 4 months ago) by tis4000
Changes since 1.16: +1 -0 lines
Diff to previous 1.16
Add Kep driver to distribution. - ncd
Revision 1.16 - (view) (annotate) - [select for diffs]
Mon Feb 5 21:22:53 2001 UTC (22 years, 7 months ago) by tis4000
Changes since 1.15: +3 -1 lines
Add Eim driver, change limitorque.o to limitorq.o, and add optrakconverter2. - ncd
Revision 1.15 - (view) (annotate) - [select for diffs]
Thu Feb 1 18:20:56 2001 UTC (22 years, 7 months ago) by tis4000
Changes since 1.14: +3 -1 lines
Add trn to HostDPA. Add libca.a to HostBaseComponent. Add Aum driver. - ndalesio
Revision 1.14 - (view) (annotate) - [select for diffs]
Thu Nov 30 14:31:44 2000 UTC (22 years, 10 months ago) by tis4000
CVS Tags: LMC_baseline
Remove CleanandArchTrak from distribution. - ndalesio
Revision 1.13 - (view) (annotate) - [select for diffs]
Tue Nov 28 20:24:51 2000 UTC (22 years, 10 months ago) by tis4000
Changes since 1.12: +2 -0 lines
Add trendvu_print and alarmvu_print to HostBaseComponent. - NDalesio
Revision 1.12 - (view) (annotate) - [select for diffs]
Tue Aug 15 17:29:05 2000 UTC (23 years, 1 month ago) by tis4000
Changes since 1.11: +5 -3 lines
Changed snc, snlvu & snlvu.vr to HostBaseComponent, Added tisAlarm.h & dbAddr.h to HostBaseHeader. - NDalesio
Revision 1.11 - (view) (annotate) - [select for diffs]
Mon Aug 14 15:25:11 2000 UTC (23 years, 1 month ago) by tis4000
Changes since 1.10: +18 -0 lines
Added CopyPrivDb.sh to HostStdBaseComponent. Added various header files to HostBaseHeader. - NDalesio
Revision 1.10 - (view) (annotate) - [select for diffs]
Fri Aug 11 18:55:54 2000 UTC (23 years, 1 month ago) by tis4000
Changes since 1.9: +0 -3 lines
Removed tagvu, tagvu.vr, tagvuServer. Replaced with the java version. - NDalesio
Revision 1.9 - (view) (annotate) - [select for diffs]
Fri Aug 11 18:17:26 2000 UTC (23 years, 1 month ago) by tis4000
Changes since 1.8: +1 -0 lines
Added emergncy.o as IOCBaseComponent. - NDalesio
Revision 1.8 - (view) (annotate) - [select for diffs]
Tue Aug 1 15:34:14 2000 UTC (23 years, 1 month ago) by tis4000
Changes since 1.7: +0 -3 lines
Removed SIS* files as a JavaClass. - NDalesio
Revision 1.7 - (view) (annotate) - [select for diffs]
Tue Aug 1 15:14:43 2000 UTC (23 years, 1 month ago) by tis4000
Removed uddsTools.o (already built into recSup.o). Added iocTime.o to IOCBaseComponent. - NDalesio
Revision 1.6 - (view) (annotate) - [select for diffs]
Tue Aug 1 14:56:53 2000 UTC (23 years, 1 month ago) by tis4000
Added uddsTools to HostBaseComponent and uddTool.o to IOCBase Component. - NDalesio
Revision 1.5 - (view) (annotate) - [select for diffs]
Thu Jul 20 14:08:34 2000 UTC (23 years, 2 months ago) by tis4000
Changes since 1.4: +14 -1 lines
Add new java classes. Aded t60optrakconverter and t60tagvuconverter. - NDalesio
Wed Jun 7 18:45:34 2000 UTC (23 years, 3 months ago) by tis4000
Added dbEmul.o and cmdplay files. - NDalesio
Mon Jun 5 12:41:53 2000 UTC (23 years, 3 months ago) by tis4000
Changed apxDispatch from HostApplix to HostNotOracle. - NDalesio
Fri Jun 2 11:58:59 2000 UTC (23 years, 3 months ago) by tis4000
Added tisTime to non-secure distributions. - NDalesio
Thu May 18 13:15:46 2000 UTC (23 years, 4 months ago) by tis4000
Upgraded versions for t60 releases. - NDalesio
Powered by ViewVC 1.1.30
