/[TIS-4000 Rel T60]/sun2.4/CalISO/Makefile
Log of /sun2.4/CalISO/Makefile
Revision 1.5 - (view) (annotate) - [select for diffs]
Thu Mar 9 17:10:45 2000 UTC (23 years, 11 months ago) by tis4000
Changes since 1.4: +2 -1 lines
Added net time program and gpc program. - Bekkerman
Mon Jan 3 20:41:49 2000 UTC (24 years, 1 month ago) by tis4000
Changes since 1.3: +26 -2 lines
Build tisTime (unsecured TCP) and/or netTime (SSL). - Bekkerman
Mon Dec 6 21:18:55 1999 UTC (24 years, 2 months ago) by tis4000
Changes since 1.2: +20 -35 lines
Change the paths. - Bekkerman
Mon Dec 6 16:58:22 1999 UTC (24 years, 2 months ago) by tis4000
Changes since 1.1: +11 -3 lines
Use new version message format, generate buildVersion.h - Bekkerman
Thu Nov 4 13:48:01 1999 UTC (24 years, 3 months ago) by tis4000
Add CalISO security software to t60 build. - Irani
Powered by ViewVC 1.1.30
