/[TIS-4000 Rel T60]/sun2.4/FileTransfer/Makefile
Log of /sun2.4/FileTransfer/Makefile
Wed Sep 29 13:41:23 1999 UTC (23 years, 8 months ago) by tis4000
CVS Tags: t55baseline
Add secure programs to clean command - irani
Wed Sep 29 13:38:43 1999 UTC (23 years, 8 months ago) by tis4000
Changes since 1.1: +54 -36 lines
Add secure program builds, add sevure libs to dependency - irani
Thu Sep 2 16:27:23 1999 UTC (23 years, 9 months ago) by tis4000
Initial baseline - Vitaly
Powered by ViewVC 1.1.28
