Log of /sun2.4/alarmVuCC/Makefile
Parent Directory
Revision Log
Revision Graph
Revision
1.6 -
view)
annotate)
[select for diffs]
Fri Mar 24 14:47:11 2000 UTC
(22 years, 10 months ago)
by
tis4000
Branch:
MAIN
Changes since
1.5: +5 -4 lines
Diff to
previous 1.5
Substitute gcc for CC to do the link so line numbers for debugging are not stripped out for gdb. Add -lC so that CC libraries are included in the link
Steel
Revision
1.5 -
view)
annotate)
[select for diffs]
Thu Mar 9 19:15:30 2000 UTC
(22 years, 11 months ago)
by
tis4000
Branch:
MAIN
Changes since
1.4: +2 -2 lines
Diff to
previous 1.4
Use libtis instead of libTisClient. Use gcc rather than CC to generate the Makefile.depend. - Steel
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
