/[TIS-4000 Rel T60]/sun2.4/alarmVuCC/Makefile
Log of /sun2.4/alarmVuCC/Makefile
Thu Aug 26 20:40:21 1999 UTC (23 years, 3 months ago) by tis4000
CVS Tags: t55baseline
Changes since 1.3: +8 -3086 lines
added Makefile.depend target instead of EPICSmakedepend
Wed Aug 25 18:52:38 1999 UTC (23 years, 3 months ago) by tis4000
chmod +w alarmConfig.vr
Fri Aug 20 18:03:46 1999 UTC (23 years, 3 months ago) by tis4000
Changes since 1.1: +3062 -3018 lines
added alarmvu.vr target
Tue Aug 3 17:11:00 1999 UTC (23 years, 4 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.28
