/[TIS-4000 Rel T60]/sun2.4/bin/Makefile
Log of /sun2.4/bin/Makefile
Revision 1.16 - (view) (annotate) - [select for diffs]
Thu Nov 30 17:10:23 2000 UTC (23 years ago) by tis4000
Changes since 1.15: +5 -0 lines
Include build command lines for trn. - tomalesky
Revision 1.15 - (view) (annotate) - [select for diffs]
Tue Jun 6 11:33:11 2000 UTC (23 years, 6 months ago) by tis4000
Changes since 1.14: +6 -1 lines
Modified the main workstation makefile to build the workstation version of uddsTools. - Steel
Revision 1.14 - (view) (annotate) - [select for diffs]
Wed May 3 14:10:08 2000 UTC (23 years, 7 months ago) by tis4000
Changes since 1.13: +1 -0 lines
Added soundPlayers to the build list. - Irani
Revision 1.13 - (view) (annotate) - [select for diffs]
Mon Apr 10 12:45:47 2000 UTC (23 years, 8 months ago) by tis4000
Changes since 1.12: +0 -1 lines
removed make depend for tankfarm, tankfarm not supported - Steel
Revision 1.12 - (view) (annotate) - [select for diffs]
Thu Mar 9 19:16:49 2000 UTC (23 years, 9 months ago) by tis4000
Changes since 1.11: +10 -1 lines
Added target diagTools and voipMon. - Steel
Revision 1.11 - (view) (annotate) - [select for diffs]
Mon Nov 8 13:33:28 1999 UTC (24 years, 1 month ago) by tis4000
CVS Tags: SPR383
Changes since 1.10: +4 -1 lines
SPR 383
Modified to include the Makefile for the "alm" utility. - Tomalesky
Revision 1.10 - (view) (annotate) - [select for diffs]
Thu Nov 4 13:36:13 1999 UTC (24 years, 1 month ago) by tis4000
Changes since 1.9: +5 -1 lines
Add build commmand to make libCallSO.a before ca directory, and make the rest of the CallSO software after library builds are completed. - Irani
Revision 1.9 - (view) (annotate) - [select for diffs]
Fri Sep 24 14:05:43 1999 UTC (24 years, 2 months ago) by tis4000
CVS Tags: t55baseline
Changes since 1.8: +2 -0 lines
added tanfarm clean and depend - Steel
Revision 1.8 - (view) (annotate) - [select for diffs]
Fri Sep 24 12:20:22 1999 UTC (24 years, 2 months ago) by tis4000
removed install from bld target, not needed - Steel
Revision 1.7 - (view) (annotate) - [select for diffs]
Thu Sep 23 20:38:11 1999 UTC (24 years, 2 months ago) by tis4000
Changes since 1.6: +0 -1 lines
removed util/extrDoc, not used - Steel
Revision 1.6 - (view) (annotate) - [select for diffs]
Thu Sep 23 19:12:29 1999 UTC (24 years, 2 months ago) by tis4000
Changes since 1.5: +0 -3 lines
removed V984, not needed - Steel
Revision 1.5 - (view) (annotate) - [select for diffs]
Wed Sep 8 19:02:15 1999 UTC (24 years, 3 months ago) by tis4000
Changes since 1.4: +3 -0 lines
added V984 - Steel
Tue Sep 7 17:05:37 1999 UTC (24 years, 3 months ago) by tis4000
Changes since 1.3: +3 -0 lines
added pager - Steel
Thu Sep 2 13:27:32 1999 UTC (24 years, 3 months ago) by tis4000
Changes since 1.2: +3 -0 lines
added FileTransfer - Steel
Fri Aug 13 14:14:51 1999 UTC (24 years, 3 months ago) by tis4000
Changes since 1.1: +3 -0 lines
13-aug-99	ems	re-added target cvs_update with call to script
			update_from_cvs
Tue Aug 3 17:10:57 1999 UTC (24 years, 4 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
