/[TIS-4000 Rel T60]/sun2.4/bin/vrsscript.sed
Log of /sun2.4/bin/vrsscript.sed
Fri Aug 11 19:01:03 2000 UTC (23 years, 3 months ago) by tis4000
chg'd t55 to t60 - Steel
Mon Dec 6 17:51:24 1999 UTC (24 years ago) by tis4000
Sed script that creates release and project definitions to be put into buildVersion.h. Must always be put and kept in ../Unix/sun2.4/bin. - Bekkerman
Powered by ViewVC 1.1.30
