/[TIS-4000 Rel T60]/sun2.4/ca/Makefile
Log of /sun2.4/ca/Makefile
Revision 1.5 - (view) (annotate) - [select for diffs]
Mon Dec 6 17:07:52 1999 UTC (24 years, 2 months ago) by tis4000
Changes since 1.4: +11 -2 lines
Use new version message format, generate buildVersion.h. - Bekkerman
Wed Sep 29 13:34:37 1999 UTC (24 years, 4 months ago) by tis4000
CVS Tags: t55baseline
Changes since 1.3: +58 -7 lines
Add secure stuff to clean, add sec libs to depends - irani
Thu Aug 26 20:44:19 1999 UTC (24 years, 6 months ago) by tis4000
Tue Aug 17 18:32:39 1999 UTC (24 years, 6 months ago) by tis4000
Changes since 1.1: +7 -675 lines
			will not confuse CVS
Tue Aug 3 17:10:58 1999 UTC (24 years, 6 months ago) by tis4000
Branch: HIA
CVS Tags: T60
Diff to previous 1.1 , to next main 1.5
Initial sun2.4 setup
Branch point for: HIA
Powered by ViewVC 1.1.30
