Log of /sun2.4/converters/Makefile
Parent Directory
Revision Log
Revision Graph
Revision
1.12 -
view)
annotate)
[select for diffs]
Mon Mar 26 14:41:48 2001 UTC
(22 years, 8 months ago)
by
tis4000
Branch:
MAIN
CVS Tags:
Duluth_baseline,
HEAD
Changes since
1.11: +4 -4 lines
Diff to
previous 1.11
Commented out copy command for t60alarmlogconverter and t60opnotesconverter.(As in previous version 1.10) - ncd
Revision
1.10 -
view)
annotate)
[select for diffs]
Mon Feb 5 21:20:57 2001 UTC
(22 years, 9 months ago)
by
tis4000
Branch:
MAIN
Changes since
1.9: +7 -7 lines
Diff to
previous 1.9
Commented out copy command for t60alarmlogconverter and t60opnotesconverter. - steel
Revision
1.8 -
view)
annotate)
[select for diffs]
Thu Feb 1 14:56:34 2001 UTC
(22 years, 10 months ago)
by
tis4000
Branch:
MAIN
Changes since
1.7: +12 -8 lines
Diff to
previous 1.7
Comment out targets t60optrakconverter2, t60opnotesconverter and t60alarmlogconverter, not ready yet
Added importconfig and exportconfig to install and clean targets - emsteel
Revision
1.7 -
view)
annotate)
[select for diffs]
Thu Feb 1 12:56:32 2001 UTC
by
tis4000
Branch:
MAIN
Changes since
1.6: +64 -3 lines
Diff to
previous 1.6
Added new targets importconfig and exportconfig. - steel
Revision
1.5 -
view)
annotate)
[select for diffs]
Mon Jul 17 12:55:28 2000 UTC
(23 years, 4 months ago)
by
tis4000
Branch:
MAIN
Changes since
1.4: +42 -4 lines
Diff to
previous 1.4
Added two utilities for converting dbase files to text and visa versa. - Russo
Revision
1.4 -
view)
annotate)
[select for diffs]
Tue Apr 4 20:00:56 2000 UTC
(23 years, 8 months ago)
by
tis4000
Branch:
MAIN
Changes since
1.3: +16 -3 lines
Diff to
previous 1.3
Convert a t51 pump database into a t60 pump database. - Steel
Revision
1.2 -
view)
annotate)
[select for diffs]
Tue Aug 17 18:35:30 1999 UTC
(24 years, 3 months ago)
by
tis4000
Branch:
MAIN
Changes since
1.1: +10 -258 lines
Diff to
previous 1.1
08-17-99 ems added target depend, which creates Makefile.depend
will not confuse CVS
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
