Log of /sun2.4/dataVuCC/Makefile
Parent Directory
Revision Log
Revision Graph
Revision
1.8 -
view)
annotate)
[select for diffs]
Tue Nov 21 14:00:30 2000 UTC
(23 years ago)
by
tis4000
Branch:
MAIN
CVS Tags:
SPR698
Changes since
1.7: +6 -0 lines
Diff to
previous 1.7
SPR 698
Added vuSyncDialogClass.o as a target and as part of the dataVu build. - steel
Revision
1.7 -
view)
annotate)
[select for diffs]
Tue Nov 7 14:28:00 2000 UTC
(23 years ago)
by
tis4000
Branch:
MAIN
CVS Tags:
SPR680
Changes since
1.6: +7 -1 lines
Diff to
previous 1.6
SPR 680
Added vuOnlineDeleteDialogClass.o as a target and as part of the dataVu build. - Steel
Revision
1.6 -
view)
annotate)
[select for diffs]
Tue Jun 6 11:36:31 2000 UTC
(23 years, 5 months ago)
by
tis4000
Branch:
MAIN
Changes since
1.5: +7 -1 lines
Diff to
previous 1.5
Modified to add new udds code to the dataVu code. - Steel
Revision
1.2 -
view)
annotate)
[select for diffs]
Tue Aug 17 18:39:44 1999 UTC
(24 years, 3 months ago)
by
tis4000
Branch:
MAIN
Changes since
1.1: +14 -10971 lines
Diff to
previous 1.1
08-17-99 ems added target depend, which creates Makefile.depend
will not confuse CVS
This form allows you to request diffs between any two revisions of this file.
For each of the two "sides" of the diff,
select a symbolic revision name using the selection box, or choose
'Use Text Field' and enter a numeric revision.
