/[TIS-4000 Rel T60]/sun2.4/dataVuCC/Makefile
Log of /sun2.4/dataVuCC/Makefile
Revision 1.9 - (view) (annotate) - [select for diffs]
Wed Jan 17 13:17:20 2001 UTC (23 years, 1 month ago) by tis4000
CVS Tags: Duluth_baseline, HEAD, LMC_baseline, SPR742
Changes since 1.8: +7 -1 lines
SPR 742
Add vuReportClass.o as a new target to be built as part of dataVu. - steel
Revision 1.8 - (view) (annotate) - [select for diffs]
Tue Nov 21 14:00:30 2000 UTC (23 years, 3 months ago) by tis4000
CVS Tags: SPR698
Changes since 1.7: +6 -0 lines
SPR 698
Added vuSyncDialogClass.o as a target and as part of the dataVu build. - steel
Revision 1.7 - (view) (annotate) - [select for diffs]
Tue Nov 7 14:28:00 2000 UTC (23 years, 3 months ago) by tis4000
CVS Tags: SPR680
Changes since 1.6: +7 -1 lines
SPR 680
Added vuOnlineDeleteDialogClass.o as a target and as part of the dataVu build. - Steel
Revision 1.6 - (view) (annotate) - [select for diffs]
Tue Jun 6 11:36:31 2000 UTC (23 years, 8 months ago) by tis4000
Changes since 1.5: +7 -1 lines
Modified to add new udds code to the dataVu code. - Steel
Revision 1.5 - (view) (annotate) - [select for diffs]
Thu Mar 9 19:18:07 2000 UTC (23 years, 11 months ago) by tis4000
Changes since 1.4: +2 -1 lines
Use libtis instead of libTisClient. - Steel
Wed Oct 20 15:00:34 1999 UTC (24 years, 4 months ago) by tis4000
CVS Tags: t55baseline
Changes since 1.3: +6 -0 lines
add vuCmdLineExportClass target - Steel
Thu Aug 26 20:48:08 1999 UTC (24 years, 6 months ago) by tis4000
Tue Aug 17 18:39:44 1999 UTC (24 years, 6 months ago) by tis4000
Changes since 1.1: +14 -10971 lines
			will not confuse CVS
Tue Aug 3 17:10:58 1999 UTC (24 years, 6 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
