/[TIS-4000 Rel T60]/sun2.4/dbFix/Makefile
Log of /sun2.4/dbFix/Makefile
Thu Aug 26 20:49:33 1999 UTC (23 years, 7 months ago) by tis4000
Tue Aug 17 18:43:44 1999 UTC (23 years, 7 months ago) by tis4000
Changes since 1.1: +11 -42 lines
			will not confuse CVS
			added all target
Tue Aug 3 17:11:00 1999 UTC (23 years, 8 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.28
