/[TIS-4000 Rel T60]/sun2.4/importapps/Makefile
Log of /sun2.4/importapps/Makefile
Default branch: HIA
Revision 1.1.1.1 - (view) (annotate) - [selected] (vendor branch)
Tue Aug 3 17:11:04 1999 UTC (24 years, 6 months ago) by tis4000
Branch: HIA, MAIN
CVS Tags: Duluth_baseline, HEAD, LMC_baseline, T60, t55baseline
Initial sun2.4 setup
Branch point for: HIA, MAIN
Diff to selected 1.1.1.1
Powered by ViewVC 1.1.30
