/[TIS-4000 Rel T60]/sun2.4/importapps/snws/Makefile
Log of /sun2.4/importapps/snws/Makefile
Thu Aug 26 20:59:47 1999 UTC (24 years, 6 months ago) by tis4000
Tue Aug 17 19:01:33 1999 UTC (24 years, 6 months ago) by tis4000
Changes since 1.1: +10 -81 lines
			will not confuse CVS
Tue Aug 3 17:11:04 1999 UTC (24 years, 6 months ago) by tis4000
Branch: HIA
CVS Tags: T60
Initial sun2.4 setup
Branch point for: HIA
Powered by ViewVC 1.1.30
