/[TIS-4000 Rel T60]/sun2.4/ims/Makefile
Log of /sun2.4/ims/Makefile
Tue Aug 3 17:11:02 1999 UTC (23 years, 7 months ago) by tis4000
Branch: HIA
CVS Tags: T60
Initial sun2.4 setup
Branch point for: HIA
Powered by ViewVC 1.1.28
