/[TIS-4000 Rel T60]/sun2.4/libtis/CopyTis4000
Log of /sun2.4/libtis/CopyTis4000
Tue Aug 31 20:57:17 1999 UTC (24 years, 6 months ago) by tis4000
Changes since 1.2: +156 -123 lines
08-31-99	ems	copy files to $loginpath/....
Mon Aug 30 15:48:45 1999 UTC (24 years, 6 months ago) by tis4000
added fieldsInfo.txt - Steel
Revision 1.1 - (view) (annotate) - [selected]
Wed Aug 25 21:28:36 1999 UTC (24 years, 6 months ago) by tis4000
initial version
Powered by ViewVC 1.1.30
