/[TIS-4000 Rel T60]/sun2.4/lpd/Makefile
Log of /sun2.4/lpd/Makefile
Default branch: HIA
Tue Aug 3 17:11:02 1999 UTC (24 years, 6 months ago) by tis4000
Branch: HIA, MAIN
CVS Tags: Duluth_baseline, HEAD, LMC_baseline, T60, t55baseline
Initial sun2.4 setup
Branch point for: HIA, MAIN
Powered by ViewVC 1.1.30
