/[TIS-4000 Rel T60]/sun2.4/opNote/Makefile
Log of /sun2.4/opNote/Makefile
Revision 1.5 - (view) (annotate) - [select for diffs]
Thu Aug 26 21:10:10 1999 UTC (23 years, 9 months ago) by tis4000
CVS Tags: t55baseline
Wed Aug 25 18:54:15 1999 UTC (23 years, 9 months ago) by tis4000
chmod +w alarmConfig.vr
Tue Aug 17 19:31:03 1999 UTC (23 years, 9 months ago) by tis4000
Changes since 1.2: +10 -1177 lines
			will not confuse CVS
Fri Aug 13 17:48:18 1999 UTC (23 years, 10 months ago) by tis4000
Changes since 1.1: +1164 -1147 lines
13-aug-99	ems	added dataVu.vr as a target
Tue Aug 3 17:11:01 1999 UTC (23 years, 10 months ago) by tis4000
Branch point for: HIA
Diff to selected 1.2
Powered by ViewVC 1.1.28
