/[TIS-4000 Rel T60]/sun2.4/operator/Makefile
Log of /sun2.4/operator/Makefile
Links to LMC_baseline: (view) (annotate)
Thu Mar 9 19:23:35 2000 UTC (23 years, 8 months ago) by tis4000
CVS Tags: Duluth_baseline, LMC_baseline
Changes since 1.3: +8 -7 lines
Operator name on graphics. - Irani
Thu Aug 26 21:10:50 1999 UTC (24 years, 3 months ago) by tis4000
CVS Tags: t55baseline
Tue Aug 17 19:33:16 1999 UTC (24 years, 3 months ago) by tis4000
Changes since 1.1: +13 -806 lines
			will not confuse CVS
Tue Aug 3 17:11:03 1999 UTC (24 years, 4 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
