/[TIS-4000 Rel T60]/sun2.4/opi/Makefile
Log of /sun2.4/opi/Makefile
Revision 1.1.1.1 - (view) (annotate) - [selected] (vendor branch)
Tue Aug 3 17:11:00 1999 UTC (23 years ago) by tis4000
Branch: HIA
CVS Tags: T60
Diff to previous 1.1 , to next main 1.2
Initial sun2.4 setup
Branch point for: HIA
Diff to selected 1.1.1.1
Powered by ViewVC 1.1.28
