/[TIS-4000 Rel T60]/sun2.4/opi/Makefile
Log of /sun2.4/opi/Makefile
Mon Aug 23 15:15:49 1999 UTC (24 years, 6 months ago) by tis4000
Changes since 1.1: +10 -2 lines
08-23-99	ems	added target opiStringTable
Revision 1.1 - (view) (annotate) - [selected]
Tue Aug 3 17:11:00 1999 UTC (24 years, 6 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
