/[TIS-4000 Rel T60]/sun2.4/opi/Makefile
Log of /sun2.4/opi/Makefile
Links to T60: (view) (annotate)
Tue Aug 3 17:11:00 1999 UTC (23 years, 6 months ago) by tis4000
Branch: HIA
CVS Tags: T60
Diff to previous 1.1 , to next main 1.2
Initial sun2.4 setup
Branch point for: HIA
Powered by ViewVC 1.1.28
