/[TIS-4000 Rel T60]/sun2.4/opi/menu/Makefile
Log of /sun2.4/opi/menu/Makefile
Links to T60: (view) (annotate)
Tue Aug 3 17:11:00 1999 UTC (24 years, 4 months ago) by tis4000
Branch: HIA
CVS Tags: T60
Initial sun2.4 setup
Branch point for: HIA
Powered by ViewVC 1.1.30
