/[TIS-4000 Rel T60]/sun2.4/sequencer/Makefile
Log of /sun2.4/sequencer/Makefile
Revision 1.6 - (view) (annotate) - [select for diffs]
Thu Aug 26 21:18:20 1999 UTC (24 years, 6 months ago) by tis4000
Revision 1.5 - (view) (annotate) - [select for diffs]
Thu Aug 26 20:24:46 1999 UTC (24 years, 6 months ago) by tis4000
added /tools/vw502/h as include
Tue Aug 17 19:58:39 1999 UTC (24 years, 6 months ago) by tis4000
			will not confuse CVS
Tue Aug 17 19:51:17 1999 UTC (24 years, 6 months ago) by tis4000
Changes since 1.2: +10 -165 lines
Fri Aug 13 17:09:22 1999 UTC (24 years, 6 months ago) by tis4000
Changes since 1.1: +149 -125 lines
13-aug-99	ems	1 - snc.c is removed from src tree and generated
			    in make directory by yacc
			2 - so was t.tab.h
			3 - so was sncVersion.c
			these files were removed fom cvs source tree since
			they are generated fiels
Tue Aug 3 17:11:02 1999 UTC (24 years, 7 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
