/[TIS-4000 Rel T60]/sun2.4/servers/Makefile
Log of /sun2.4/servers/Makefile
Revision 1.6 - (view) (annotate) - [select for diffs]
Tue Jul 10 17:32:53 2001 UTC (22 years, 4 months ago) by tis4000
CVS Tags: Duluth_baseline, HEAD
comment out copy of trendata, not bieing built at this time - Steel
Revision 1.5 - (view) (annotate) - [select for diffs]
Mon Jul 9 19:49:35 2001 UTC (22 years, 4 months ago) by tis4000
Changes since 1.4: +101 -34 lines
Add new targets for oracle snap edit. - ems
Mon Dec 6 17:33:58 1999 UTC (23 years, 11 months ago) by tis4000
CVS Tags: LMC_baseline
Changes since 1.3: +11 -2 lines
Use new version message format, generate buildVersion.h - Bekkerman
Thu Aug 26 21:18:56 1999 UTC (24 years, 3 months ago) by tis4000
CVS Tags: t55baseline
Wed Aug 18 13:29:24 1999 UTC (24 years, 3 months ago) by tis4000
Changes since 1.1: +13 -290 lines
08-18-99	ems	commented out trenddata.c from SRCS, not built
			and requires trendfils.h and defines.h that need
			to be resurected for t60
Tue Aug 3 17:10:58 1999 UTC (24 years, 4 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
