/[TIS-4000 Rel T60]/sun2.4/snlvuCC/Makefile
Log of /sun2.4/snlvuCC/Makefile
Thu Aug 26 21:20:20 1999 UTC (23 years, 3 months ago) by tis4000
CVS Tags: t55baseline
Tue Aug 17 20:28:04 1999 UTC (23 years, 3 months ago) by tis4000
Changes since 1.2: +10 -2013 lines
			will not confuse CVS
Fri Aug 13 17:53:44 1999 UTC (23 years, 3 months ago) by tis4000
Changes since 1.1: +1996 -1977 lines
13-aug-99	ems	added snlvu.vr target
Tue Aug 3 17:11:03 1999 UTC (23 years, 4 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.28
