/[TIS-4000 Rel T60]/sun2.4/snlvuCC/Makefile
Log of /sun2.4/snlvuCC/Makefile
Revision 1.5 - (view) (annotate) - [select for diffs]
Thu Mar 9 19:26:39 2000 UTC (23 years ago) by tis4000
Use libtis instead of libTisClient. - Steel
Thu Aug 26 21:20:20 1999 UTC (23 years, 7 months ago) by tis4000
CVS Tags: t55baseline
Tue Aug 17 20:28:04 1999 UTC (23 years, 7 months ago) by tis4000
Changes since 1.2: +10 -2013 lines
			will not confuse CVS
Fri Aug 13 17:53:44 1999 UTC (23 years, 7 months ago) by tis4000
Changes since 1.1: +1996 -1977 lines
13-aug-99	ems	added snlvu.vr target
Tue Aug 3 17:11:03 1999 UTC (23 years, 7 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.28
