/[TIS-4000 Rel T60]/sun2.4/tagvuCC/Makefile
Log of /sun2.4/tagvuCC/Makefile
Thu Aug 26 21:21:00 1999 UTC (23 years, 3 months ago) by tis4000
CVS Tags: t55baseline
Tue Aug 17 20:31:00 1999 UTC (23 years, 3 months ago) by tis4000
Changes since 1.2: +10 -1035 lines
			will not confuse CVS
Fri Aug 13 18:00:24 1999 UTC (23 years, 3 months ago) by tis4000
Changes since 1.1: +1021 -996 lines
 added tagvu.vr as a target
Tue Aug 3 17:11:02 1999 UTC (23 years, 4 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.28
