/[TIS-4000 Rel T60]/sun2.4/tankfarm/Makefile
Log of /sun2.4/tankfarm/Makefile
Fri Sep 24 14:06:45 1999 UTC (24 years, 5 months ago) by tis4000
Changes since 1.2: +18 -11 lines
mods to use solaris dt, codebase63 - Steel
Tue Aug 17 20:32:36 1999 UTC (24 years, 6 months ago) by tis4000
Changes since 1.1: +8 -9 lines
			will not confuse CVS
Tue Aug 3 17:11:03 1999 UTC (24 years, 6 months ago) by tis4000
Branch: HIA
CVS Tags: T60
Initial sun2.4 setup
Branch point for: HIA
Powered by ViewVC 1.1.30
