/[TIS-4000 Rel T60]/sun2.4/tisPermissions/Makefile
Log of /sun2.4/tisPermissions/Makefile
Revision 1.9 - (view) (annotate) - [select for diffs]
Mon Aug 14 15:21:25 2000 UTC (23 years, 6 months ago) by tis4000
Changes since 1.8: +2 -0 lines
Copy CopyPrivDb.sh to bin. - Steel
Revision 1.8 - (view) (annotate) - [select for diffs]
Mon Nov 29 18:20:33 1999 UTC (24 years, 3 months ago) by tis4000
Changes since 1.7: +1 -0 lines
Change the Makefile to include dataVuCC in the search path for header files. - Steel
Revision 1.7 - (view) (annotate) - [select for diffs]
Fri Nov 12 13:59:22 1999 UTC (24 years, 3 months ago) by tis4000
Changes since 1.6: +2 -2 lines
1)Corrected a misspelling on secTisPermissions.
2)Added secTisPermissions to install target. - Steel
Revision 1.6 - (view) (annotate) - [select for diffs]
Mon Nov 8 13:38:11 1999 UTC (24 years, 3 months ago) by tis4000
CVS Tags: SPR384
Changes since 1.5: +83 -1 lines
SPR 384
Fixed to generate a secure tisPermissions. - Steel
Revision 1.5 - (view) (annotate) - [select for diffs]
Mon Aug 30 15:46:18 1999 UTC (24 years, 6 months ago) by tis4000
CVS Tags: t55baseline
added fieldsInfo.txt to install target - Steel
Thu Aug 26 21:25:01 1999 UTC (24 years, 6 months ago) by tis4000
Tue Aug 17 20:42:26 1999 UTC (24 years, 6 months ago) by tis4000
Changes since 1.2: +10 -2230 lines
			will not confuse CVS
Fri Aug 13 20:27:12 1999 UTC (24 years, 6 months ago) by tis4000
Changes since 1.1: +2215 -2195 lines
13-aug-99	ems	added target tisPermissions.vr
Tue Aug 3 17:10:58 1999 UTC (24 years, 7 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
