/[TIS-4000 Rel T60]/sun2.4/trendvuCC/Makefile
Log of /sun2.4/trendvuCC/Makefile
Revision 1.9 - (view) (annotate) - [select for diffs]
Tue Nov 28 20:21:00 2000 UTC (23 years ago) by tis4000
Changes since 1.8: +2 -0 lines
Add copy of trendvu_print to tasks. - NDalesio
Revision 1.8 - (view) (annotate) - [select for diffs]
Tue Aug 1 12:22:40 2000 UTC (23 years, 4 months ago) by tis4000
Changes since 1.7: +27 -2 lines
Compile oracleTrendvu.o object with ORACLESNAP define. - Irani
Revision 1.7 - (view) (annotate) - [select for diffs]
Tue May 2 18:23:06 2000 UTC (23 years, 7 months ago) by tis4000
Changes since 1.6: +38 -1 lines
Link executable for oracleTrendvu version, copy trendvu.vr to oracleTrendvu.vr, adjust install to copy both targets. - Irani
Revision 1.6 - (view) (annotate) - [select for diffs]
Mon Apr 10 20:49:23 2000 UTC (23 years, 7 months ago) by tis4000
Changes since 1.5: +22 -4 lines
Added alarm and alarmVu to include path. Changed trendnotedlg to trendnotesdlg. Added trendfmt.o and alpvmap.o targets. - Irani
Revision 1.5 - (view) (annotate) - [select for diffs]
Thu Mar 9 19:29:56 2000 UTC (23 years, 8 months ago) by tis4000
Use libtis instead of libTisClient. - Steel
Thu Aug 26 21:26:54 1999 UTC (24 years, 3 months ago) by tis4000
CVS Tags: t55baseline
Tue Aug 17 20:57:01 1999 UTC (24 years, 3 months ago) by tis4000
Changes since 1.2: +10 -2589 lines
			will not confuse CVS
Mon Aug 16 12:52:16 1999 UTC (24 years, 3 months ago) by tis4000
Changes since 1.1: +2567 -2542 lines
added target tagvu.vr
Tue Aug 3 17:11:02 1999 UTC (24 years, 4 months ago) by tis4000
Branch point for: HIA
Powered by ViewVC 1.1.30
