EPICS Base
7.0.6.1
API for monitoring external put operations to an IOC. More...
#include "libComAPI.h"
Classes | |
| struct | asTrapWriteMessage |
| The message passed to registered listeners. More... | |
Typedefs | |
| typedef void * | asTrapWriteId |
| An identifier needed to unregister an listener. | |
| typedef void(* | asTrapWriteListener )(asTrapWriteMessage *pmessage, int after) |
| Pointer to a listener function. More... | |
Functions | |
| LIBCOM_API asTrapWriteId epicsStdCall | asTrapWriteRegisterListener (asTrapWriteListener func) |
| Register function to be called on asTrapWriteListener. More... | |
| LIBCOM_API void epicsStdCall | asTrapWriteUnregisterListener (asTrapWriteId id) |
| Unregister asTrapWriteListener. More... | |
The access security subsystem provides an API asTrapWrite that makes put/write requests visible to any facility that registers a listener.
Definition in file asTrapWrite.h.
| typedef void(* asTrapWriteListener)(asTrapWriteMessage *pmessage, int after) |
Each registered listener function is called twice for every put; once before and once after the write is performed. The listener may set userPvt in the first call and retrieve it in the second call.
Each asTrapWriteMessage can change or may be deleted after the user's asTrapWriteListener returns
The listener function is called by a server thread so it must not block or do anything that causes a delay.
Definition at line 75 of file asTrapWrite.h.
| LIBCOM_API asTrapWriteId epicsStdCall asTrapWriteRegisterListener | ( | asTrapWriteListener | func | ) |
| func | The listener function to be called. |
| LIBCOM_API void epicsStdCall asTrapWriteUnregisterListener | ( | asTrapWriteId | id | ) |
| id | Listener identifier from asTrapWriteRegisterListener(). |
1.8.5
