EPICS Base  7.0.6.1
Classes | Typedefs | Enumerations | Functions
bucketLib.h File Reference
A hash table. Do not use for new code. More...
#include "errMdef.h"
#include "epicsTypes.h"
#include "libComAPI.h"
Include dependency graph for bucketLib.h:
This graph shows which files directly or indirectly include this file:
Classes
struct  ITEM
 Internal: bucket item structure. More...
struct  BUCKET
 Internal: Hash table structure. More...
Macros
Status values returned by some bucketLib functions
#define BUCKET_SUCCESS   S_bucket_success
 A synonym for S_bucket_success.
#define S_bucket_success   0
 Success, must be 0.
#define S_bucket_noMemory   (M_bucket | 1) /*Memory allocation failed*/
 Memory allocation failed.
#define S_bucket_idInUse   (M_bucket | 2) /*Identifier already in use*/
 Identifier already in use.
#define S_bucket_uknId   (M_bucket | 3) /*Unknown identifier*/
 Unknown identifier.
Typedefs
typedef unsigned BUCKETID
 Internal: bucket identifier.
Enumerations
enum  buckTypeOfId { bidtUnsigned, bidtPointer, bidtString }
 Internal: bucket key type.
Functions
LIBCOM_API BUCKET *epicsStdCall bucketCreate (unsigned nHashTableEntries)
 Creates a new hash table. More...
LIBCOM_API int epicsStdCall bucketFree (BUCKET *prb)
 Release memory used by a hash table. More...
LIBCOM_API int epicsStdCall bucketShow (BUCKET *prb)
 Display information about a hash table. More...
LIBCOM_API int epicsStdCall bucketAddItemUnsignedId (BUCKET *prb, const unsigned *pId, const void *pApp)
 Add an item identified by an unsigned int to the table. More...
LIBCOM_API int epicsStdCall bucketAddItemPointerId (BUCKET *prb, void *const *pId, const void *pApp)
 Add an item identified by a pointer to the table. More...
LIBCOM_API int epicsStdCall bucketAddItemStringId (BUCKET *prb, const char *pId, const void *pApp)
 Add an item identified by a string to the table. More...
LIBCOM_API int epicsStdCall bucketRemoveItemUnsignedId (BUCKET *prb, const unsigned *pId)
 Remove an item identified by a string from the table. More...
LIBCOM_API int epicsStdCall bucketRemoveItemPointerId (BUCKET *prb, void *const *pId)
 Remove an item identified by a pointer from the table. More...
LIBCOM_API int epicsStdCall bucketRemoveItemStringId (BUCKET *prb, const char *pId)
LIBCOM_API void *epicsStdCall bucketLookupItemUnsignedId (BUCKET *prb, const unsigned *pId)
 Find an item identified by an unsigned int in the table. More...
LIBCOM_API void *epicsStdCall bucketLookupItemPointerId (BUCKET *prb, void *const *pId)
 Find an item identified by a pointer in the table. More...
LIBCOM_API void *epicsStdCall bucketLookupItemStringId (BUCKET *prb, const char *pId)
 Find an item identified by a string in the table. More...
LIBCOM_API void *epicsStdCall bucketLookupAndRemoveItemUnsignedId (BUCKET *prb, const unsigned *pId)
 Find and delete an item identified by an unsigned int from the table. More...
LIBCOM_API void *epicsStdCall bucketLookupAndRemoveItemPointerId (BUCKET *prb, void *const *pId)
 Find and delete an item identified by a pointer from the table. More...
LIBCOM_API void *epicsStdCall bucketLookupAndRemoveItemStringId (BUCKET *prb, const char *pId)
 Find and delete an item identified by a string from the table. More...
Detailed Description
Author
Jeffrey O. Hill
A hash table for which keys may be unsigned integers, pointers, or strings. This API is used by the IOC's Channel Access Server, but it should not be used by other code.
Note
Storage for identifiers must persist until an item is deleted
Definition in file bucketLib.h.
Function Documentation
LIBCOM_API BUCKET* epicsStdCall bucketCreate ( unsigned  nHashTableEntries)
Parameters
nHashTableEntriesTable size
Returns
Pointer to the newly created hash table, or NULL.
LIBCOM_API int epicsStdCall bucketFree ( BUCKET *  prb)
Parameters
*prbPointer to the hash table
Returns
S_bucket_success
Note
All items must be deleted from the hash table before calling this.
LIBCOM_API int epicsStdCall bucketShow ( BUCKET *  prb)
Parameters
Returns
S_bucket_success
LIBCOM_API int epicsStdCall bucketAddItemUnsignedId ( BUCKET *  prb,
const unsigned *  pId,
const void *  pApp
Parameters
*pIdPointer to the identifier
*pAppPointer to the payload
Returns
Status value
LIBCOM_API int epicsStdCall bucketAddItemPointerId ( BUCKET *  prb,
void *const *  pId,
const void *  pApp
Parameters
Returns
Status value
LIBCOM_API int epicsStdCall bucketAddItemStringId ( BUCKET *  prb,
const char *  pId,
const void *  pApp
Parameters
Returns
Status value
LIBCOM_API int epicsStdCall bucketRemoveItemUnsignedId ( BUCKET *  prb,
Parameters
Returns
Status value
LIBCOM_API int epicsStdCall bucketRemoveItemPointerId ( BUCKET *  prb,
void *const *  pId
Parameters
Returns
Status value
LIBCOM_API int epicsStdCall bucketRemoveItemStringId ( BUCKET *  prb,
const char *  pId
Parameters
Returns
Status value
LIBCOM_API void* epicsStdCall bucketLookupItemUnsignedId ( BUCKET *  prb,
Parameters
Returns
Item's payload pointer, or NULL if not found
LIBCOM_API void* epicsStdCall bucketLookupItemPointerId ( BUCKET *  prb,
void *const *  pId
Parameters
Returns
LIBCOM_API void* epicsStdCall bucketLookupItemStringId ( BUCKET *  prb,
const char *  pId
Parameters
Returns
LIBCOM_API void* epicsStdCall bucketLookupAndRemoveItemUnsignedId ( BUCKET *  prb,
Parameters
Returns
LIBCOM_API void* epicsStdCall bucketLookupAndRemoveItemPointerId ( BUCKET *  prb,
void *const *  pId
Parameters
Returns
LIBCOM_API void* epicsStdCall bucketLookupAndRemoveItemStringId ( BUCKET *  prb,
const char *  pId
Parameters
Returns
