EPICS Base
7.0.6.1
Routines for code that can't continue or return after an error. More...
Functions | |
| LIBCOM_API void | cantProceed (const char *errorMessage,...) EPICS_PRINTF_STYLE(1 |
| Suspend this thread, the caller cannot continue or return. More... | |
Memory Allocation Functions | |
These versions of calloc() and malloc() never fail, they suspend the thread if the OS is unable to allocate the requested memory at the current time. If the thread is resumed, they will re-try the memory allocation, and will only return after it succeeds. These routines should only be used while an IOC is starting up; code that runs after iocInit() should fail gracefully when memory runs out. | |
| LIBCOM_API void * | callocMustSucceed (size_t count, size_t size, const char *errorMessage) |
| A calloc() that never returns NULL. More... | |
| LIBCOM_API void * | mallocMustSucceed (size_t size, const char *errorMessage) |
| A malloc() that never returns NULL. More... | |
This is the EPICS equivalent of a Kernel Panic, except that the effect is to halt only the thread that detects the error.
Definition in file cantProceed.h.
| LIBCOM_API void cantProceed | ( | const char * | errorMessage, |
The effect of calling this is to print the error message followed by the name of the thread that is being suspended. A stack trace will also be shown if supported by the OS, and the thread is suspended inside an infinite loop.
| errorMessage | A printf-style error message describing the error. |
| ... | Any parameters required for the error message. |
| LIBCOM_API void* callocMustSucceed | ( | size_t | count, |
| size_t | size, | ||
| const char * | errorMessage | ||
| count | Number of objects. |
| size | Size of each object. |
| errorMessage | What this memory is needed for. |
| LIBCOM_API void* mallocMustSucceed | ( | size_t | size, |
| size | Size of block to allocate. |
1.8.5
