EPICS Base  7.0.6.1
Classes | Macros | Enumerations | Functions
chfPlugin.h File Reference
Channel filter simplified plugins. More...
#include <dbCoreAPI.h>
#include <dbDefs.h>
#include <epicsTypes.h>
#include <dbChannel.h>
Include dependency graph for chfPlugin.h:
Classes
struct  chfPluginIf
 Channel filter simplified plugin interface. More...
struct  chfPluginEnumType
struct  chfPluginArgDef
Macros
#define chfInt32(Struct, Member, Name, Req, Conv)
#define chfBoolean(Struct, Member, Name, Req, Conv)
#define chfDouble(Struct, Member, Name, Req, Conv)
#define chfString(Struct, Member, Name, Req, Conv)
#define chfEnum(Struct, Member, Name, Req, Conv, Enums)
#define chfTagInt32(Struct, Member, Name, Tag, Choice, Req, Conv)
#define chfTagBoolean(Struct, Member, Name, Tag, Choice, Req, Conv)
#define chfTagDouble(Struct, Member, Name, Tag, Choice, Req, Conv)
#define chfTagString(Struct, Member, Name, Tag, Choice, Req, Conv)
#define chfTagEnum(Struct, Member, Name, Tag, Choice, Req, Conv, Enums)
#define chfPluginArgEnd   {0}
#define CHFPLUGINDEBUG   1
Enumerations
enum  chfPluginArg {
  chfPluginArgInvalid =0, chfPluginArgBoolean, chfPluginArgInt32, chfPluginArgDouble,
  chfPluginArgString, chfPluginArgEnum
Functions
DBCORE_API const char * chfPluginEnumString (const chfPluginEnumType *Enums, int i, const char *def)
 Return the string associated with Enum index 'i'. More...
DBCORE_API int chfPluginRegister (const char *key, const chfPluginIf *pif, const chfPluginArgDef *opts)
 Register a plugin. More...
Detailed Description
Utility layer to allow an easier (reduced) interface for channel filter plugins.
Parsing the configuration arguments of a channel filter plugin is done according to an argument description table provided by the plugin. The parser stores the results directly into a user supplied structure after appropriate type conversion.
To specify the arguments, a chfPluginArgDef table must be defined for the user structure. This table has to be specified when the plugin registers.
The plugin is responsible to register an init function using epicsExportRegistrar() and the accompanying registrar() directive in the dbd, and call chfPluginRegister() from within the init function.
For example:
typedef struct myStruct { ... other stuff char mode; epicsInt32 ival; double dval; epicsInt32 ival2; int enumval; char strval[20]; char boolval; } myStruct;
static const chfPluginEnumType colorEnum[] = { {"Red",1}, {"Green",2}, {"Blue",3}, {NULL,0} };
static const chfPluginDef myStructDef[] = { chfTagInt32(myStruct, ival, "Integer" , ival2, 3, 0, 0), chfInt32 (myStruct, ival2, "Second" , 1, 0), chfDouble (myStruct, dval, "Double" , 1, 0), chfString (myStruct, strval , "String" , 1, 0), chfEnum (myStruct, enumval, "Color" , 1, 0, colorEnum), chfBoolean (myStruct, boolval, "Bool" , 1, 0), chfPluginEnd };
Note: The 4th argument specifies the parameter to be required (1) or optional (0), the 5th whether converting to the required type is allowed (1), or type mismatches are an error (0). Note: The "Tag" version has two additional arguments. the 4th arg specifies the tag field (integer type) inside the structure to be set, the 5th arg specifies the value to set the tag field to. Arguments 6 and 7 specify "required" and "conversion" as described above.
Definition in file chfPlugin.h.
Macro Definition Documentation
#define chfInt32 (   Struct,
  Member,
  Name,
  Req,
  Conv
Value:
{Name, chfPluginArgInt32, Req, Conv, 0, 0, 0, \
OFFSET(Struct, Member), sizeof( ((Struct*)0)->Member ), NULL}
#define OFFSET(structure, member)
Deprecated synonym for offsetof.
Definition: dbDefs.h:47
Definition at line 251 of file chfPlugin.h.
#define chfBoolean (   Struct,
  Member,
  Name,
  Req,
  Conv
Value:
{Name, chfPluginArgBoolean, Req, Conv, 0, 0, 0, \
Definition at line 255 of file chfPlugin.h.
#define chfDouble (   Struct,
  Member,
  Name,
  Req,
  Conv
Value:
{Name, chfPluginArgDouble, Req, Conv, 0, 0, 0, \
Definition at line 259 of file chfPlugin.h.
#define chfString (   Struct,
  Member,
  Name,
  Req,
  Conv
Value:
{Name, chfPluginArgString, Req, Conv, 0, 0, 0, \
Definition at line 263 of file chfPlugin.h.
#define chfEnum (   Struct,
  Member,
  Name,
  Req,
  Conv,
  Enums
Value:
{Name, chfPluginArgEnum, Req, Conv, 0, 0, 0, \
OFFSET(Struct, Member), sizeof( ((Struct*)0)->Member ), Enums}
Definition at line 267 of file chfPlugin.h.
#define chfTagInt32 (   Struct,
  Member,
  Name,
  Tag,
  Choice,
  Req,
  Conv
Value:
{Name, chfPluginArgInt32, Req, Conv, 1, OFFSET(Struct, Tag), Choice, \
Definition at line 273 of file chfPlugin.h.
#define chfTagBoolean (   Struct,
  Member,
  Name,
  Tag,
  Choice,
  Req,
  Conv
Value:
{Name, chfPluginArgBoolean, Req, Conv, 1, OFFSET(Struct, Tag), Choice, \
Definition at line 277 of file chfPlugin.h.
#define chfTagDouble (   Struct,
  Member,
  Name,
  Tag,
  Choice,
  Req,
  Conv
Value:
{Name, chfPluginArgDouble, Req, Conv, 1, OFFSET(Struct, Tag), Choice, \
Definition at line 281 of file chfPlugin.h.
#define chfTagString (   Struct,
  Member,
  Name,
  Tag,
  Choice,
  Req,
  Conv
Value:
{Name, chfPluginArgString, Req, Conv, 1, OFFSET(Struct, Tag), Choice, \
Definition at line 285 of file chfPlugin.h.
#define chfTagEnum (   Struct,
  Member,
  Name,
  Tag,
  Choice,
  Req,
  Conv,
  Enums
Value:
{Name, chfPluginArgEnum, Req, Conv, 1, OFFSET(Struct, Tag), Choice, \
Definition at line 289 of file chfPlugin.h.
Function Documentation
DBCORE_API const char* chfPluginEnumString ( const chfPluginEnumType *  Enums,
int  i,
const char *  def
Parameters
EnumsA null-terminated array of string/integer pairs.
iAn Enum index.
defString to be returned when 'i' isn't a valid Enum index.
Returns
The string associated with 'i'.
DBCORE_API int chfPluginRegister ( const char *  key,
const chfPluginIf *  pif,
const chfPluginArgDef *  opts
Parameters
keyThe plugin name key that clients will use.
pifPointer to the plugin's interface.
optsPointer to the configuration argument description table.
