EPICS Base  7.0.6.1
Classes | Functions | Variables
envDefs.h File Reference
Routines to get and set EPICS environment parameters. More...
#include "libComAPI.h"
Include dependency graph for envDefs.h:
This graph shows which files directly or indirectly include this file:
Classes
struct  ENV_PARAM
 A structure to hold a single environment parameter. More...
Functions
LIBCOM_API char *epicsStdCall envGetConfigParam (const ENV_PARAM *pParam, int bufDim, char *pBuf)
 Get value of a configuration parameter. More...
LIBCOM_API const char *epicsStdCall envGetConfigParamPtr (const ENV_PARAM *pParam)
 Get a configuration parameter's value or default string. More...
LIBCOM_API long epicsStdCall envPrtConfigParam (const ENV_PARAM *pParam)
 Print the value of a configuration parameter. More...
LIBCOM_API long epicsStdCall envGetInetAddrConfigParam (const ENV_PARAM *pParam, struct in_addr *pAddr)
 Get value of an inet addr config parameter. More...
LIBCOM_API long epicsStdCall envGetDoubleConfigParam (const ENV_PARAM *pParam, double *pDouble)
 Get value of a double configuration parameter. More...
LIBCOM_API long epicsStdCall envGetLongConfigParam (const ENV_PARAM *pParam, long *pLong)
 Get value of a long configuration parameter. More...
LIBCOM_API unsigned short
epicsStdCall
envGetInetPortConfigParam (const ENV_PARAM *pEnv, unsigned short defaultPort)
 Get value of a port number configuration parameter. More...
LIBCOM_API long epicsStdCall envGetBoolConfigParam (const ENV_PARAM *pParam, int *pBool)
 Get value of a boolean configuration parameter. More...
LIBCOM_API long epicsStdCall epicsPrtEnvParams (void)
 Prints all configuration parameters and their current value. More...
LIBCOM_API void epicsStdCall epicsEnvSet (const char *name, const char *value)
 Set an environment variable's value. More...
LIBCOM_API void epicsStdCall epicsEnvUnset (const char *name)
 Clear the value of an environment variable. More...
LIBCOM_API void epicsStdCall epicsEnvShow (const char *name)
 Print value of an environment variable, or all variables. More...
Variables
LIBCOM_API const ENV_PARAM EPICS_CA_ADDR_LIST
LIBCOM_API const ENV_PARAM EPICS_CA_CONN_TMO
LIBCOM_API const ENV_PARAM EPICS_CA_AUTO_ADDR_LIST
LIBCOM_API const ENV_PARAM EPICS_CA_REPEATER_PORT
LIBCOM_API const ENV_PARAM EPICS_CA_SERVER_PORT
LIBCOM_API const ENV_PARAM EPICS_CA_MAX_ARRAY_BYTES
LIBCOM_API const ENV_PARAM EPICS_CA_AUTO_ARRAY_BYTES
LIBCOM_API const ENV_PARAM EPICS_CA_MAX_SEARCH_PERIOD
LIBCOM_API const ENV_PARAM EPICS_CA_NAME_SERVERS
LIBCOM_API const ENV_PARAM EPICS_CA_MCAST_TTL
LIBCOM_API const ENV_PARAM EPICS_CAS_INTF_ADDR_LIST
LIBCOM_API const ENV_PARAM EPICS_CAS_IGNORE_ADDR_LIST
LIBCOM_API const ENV_PARAM EPICS_CAS_AUTO_BEACON_ADDR_LIST
LIBCOM_API const ENV_PARAM EPICS_CAS_BEACON_ADDR_LIST
LIBCOM_API const ENV_PARAM EPICS_CAS_SERVER_PORT
LIBCOM_API const ENV_PARAM EPICS_CA_BEACON_PERIOD
 deprecated
LIBCOM_API const ENV_PARAM EPICS_CAS_BEACON_PERIOD
LIBCOM_API const ENV_PARAM EPICS_CAS_BEACON_PORT
LIBCOM_API const ENV_PARAM EPICS_BUILD_COMPILER_CLASS
LIBCOM_API const ENV_PARAM EPICS_BUILD_OS_CLASS
LIBCOM_API const ENV_PARAM EPICS_BUILD_TARGET_ARCH
LIBCOM_API const ENV_PARAM EPICS_TZ
LIBCOM_API const ENV_PARAM EPICS_TS_NTP_INET
LIBCOM_API const ENV_PARAM EPICS_IOC_IGNORE_SERVERS
LIBCOM_API const ENV_PARAM EPICS_IOC_LOG_PORT
LIBCOM_API const ENV_PARAM EPICS_IOC_LOG_INET
LIBCOM_API const ENV_PARAM EPICS_IOC_LOG_FILE_LIMIT
LIBCOM_API const ENV_PARAM EPICS_IOC_LOG_FILE_NAME
LIBCOM_API const ENV_PARAM EPICS_IOC_LOG_FILE_COMMAND
LIBCOM_API const ENV_PARAM IOCSH_PS1
LIBCOM_API const ENV_PARAM IOCSH_HISTSIZE
LIBCOM_API const ENV_PARAM IOCSH_HISTEDIT_DISABLE
LIBCOM_API const ENV_PARAM * env_param_list []
Detailed Description
Author
Roger A. Cole
This file defines environment parameters used by EPICS and the routines used to get and set those parameter values.
The ENV_PARAM's declared here are defined in the generated file envData.c by the bldEnvData.pl Perl script, which parses this file and the build system's CONFIG_ENV and CONFIG_SITE_ENV files. User programs can define their own environment parameters for their own use–the only caveat is that such parameters aren't automatically setup by EPICS.
Note
bldEnvData.pl looks for "LIBCOM_API extern const ENV_PARAM <name>;"
Definition in file envDefs.h.
Function Documentation
LIBCOM_API char* epicsStdCall envGetConfigParam ( const ENV_PARAM *  pParam,
int  bufDim,
char *  pBuf
Gets the value of a configuration parameter from the environment and copies it into the caller's buffer. If the parameter isn't set in the environment, the default value for the parameter is copied instead. If neither provides a non-empty string the buffer is set to '\0' and NULL is returned.
Parameters
pParamPointer to config param structure.
bufDimDimension of parameter buffer
pBufPointer to parameter buffer
Returns
Pointer to the environment variable value string, or NULL if no parameter value and default value was empty.
LIBCOM_API const char* epicsStdCall envGetConfigParamPtr ( const ENV_PARAM *  pParam)
Parameters
Returns
Pointer to the environment variable value string, or to the default value for the parameter, or NULL if those strings were empty or not set.
LIBCOM_API long epicsStdCall envPrtConfigParam ( const ENV_PARAM *  pParam)
Parameters
Returns
0
LIBCOM_API long epicsStdCall envGetInetAddrConfigParam ( const ENV_PARAM *  pParam,
struct in_addr *  pAddr
Gets the value of a configuration parameter and copies it into the caller's (struct in_addr) buffer. If the configuration parameter isn't found in the environment, the default value for that parameter will be used. The resulting string is converted from a dotted-quad format or looked up using the DNS and copied into the inet structure.
If no parameter is found and there is no default, then -1 is returned and the callers buffer is unmodified.
Parameters
pAddrPointer to struct to receive inet addr.
Returns
0, or -1 if an error is encountered
LIBCOM_API long epicsStdCall envGetDoubleConfigParam ( const ENV_PARAM *  pParam,
double *  pDouble
Gets the value of a configuration parameter, converts it into a double value and copies that into the caller's buffer. If the configuration parameter isn't found in the environment, the default value for the parameter is used instead.
Parameters
pDoublePointer to place to store value.
Returns
LIBCOM_API long epicsStdCall envGetLongConfigParam ( const ENV_PARAM *  pParam,
long *  pLong
Gets the value of a configuration parameter, converts it into a long value and copies that into the caller's buffer. If the configuration parameter isn't found in the environment, the default value for the parameter is used instead.
Parameters
pLongPointer to place to store value.
Returns
LIBCOM_API unsigned short epicsStdCall envGetInetPortConfigParam ( const ENV_PARAM *  pEnv,
Returns the value of a configuration parameter that represents an inet port number. If no environment variable is found the default parameter value is used, and if that is also unset the defaultPort argument returned instead. The integer value must fall between the values IPPORT_USERRESERVED and USHRT_MAX or the defaultPort argument will be substituted instead.
Parameters
pEnvPointer to config param structure.
defaultPortPort number to be used if environment settings invalid.
Returns
Port number.
LIBCOM_API long epicsStdCall envGetBoolConfigParam ( const ENV_PARAM *  pParam,
int *  pBool
Gets the value of a configuration parameter, and puts the value 0 or 1 into the caller's buffer depending on the value. If the configuration parameter isn't found in the environment, the default value for the parameter is used instead.
A value is treated as True (1) if it compares equal to the string "yes" with a case-independent string comparison. All other strings are treated as False (0).
Parameters
pBoolPointer to place to store value.
Returns
LIBCOM_API long epicsStdCall epicsPrtEnvParams ( void  )
Returns
0
LIBCOM_API void epicsStdCall epicsEnvSet ( const char *  name,
const char *  value
The setenv() routine is not available on all operating systems. This routine provides a portable alternative for all EPICS targets.
Parameters
nameEnvironment variable name.
valueNew value for environment variable.
LIBCOM_API void epicsStdCall epicsEnvUnset ( const char *  name)
Parameters
LIBCOM_API void epicsStdCall epicsEnvShow ( const char *  name)
Parameters
nameEnvironment variable name, or NULL to show all.
