EPICS Base
7.0.6.1
A circular buffer to store bytes. More...
#include "libComAPI.h"
Typedefs | |
| typedef void * | epicsRingBytesId |
| An identifier for a ring buffer. | |
| typedef void const * | epicsRingBytesIdConst |
Functions | |
| LIBCOM_API epicsRingBytesId epicsStdCall | epicsRingBytesCreate (int nbytes) |
| Create a new ring buffer. More... | |
| LIBCOM_API epicsRingBytesId epicsStdCall | epicsRingBytesLockedCreate (int nbytes) |
| Create a new ring buffer, secured by a spinlock. More... | |
| LIBCOM_API void epicsStdCall | epicsRingBytesDelete (epicsRingBytesId id) |
| Delete the ring buffer and free any associated memory. More... | |
| LIBCOM_API int epicsStdCall | epicsRingBytesGet (epicsRingBytesId id, char *value, int nbytes) |
| Read data out of the ring buffer. More... | |
| LIBCOM_API int epicsStdCall | epicsRingBytesPut (epicsRingBytesId id, char *value, int nbytes) |
| Write data into the ring buffer. More... | |
| LIBCOM_API void epicsStdCall | epicsRingBytesFlush (epicsRingBytesId id) |
| Make the ring buffer empty. More... | |
| LIBCOM_API int epicsStdCall | epicsRingBytesFreeBytes (epicsRingBytesId id) |
| Return the number of free bytes in the ring buffer. More... | |
| LIBCOM_API int epicsStdCall | epicsRingBytesUsedBytes (epicsRingBytesId id) |
| Return the number of bytes currently stored in the ring buffer. More... | |
| LIBCOM_API int epicsStdCall | epicsRingBytesSize (epicsRingBytesId id) |
| Return the size of the ring buffer. More... | |
| LIBCOM_API int epicsStdCall | epicsRingBytesIsEmpty (epicsRingBytesId id) |
| Test if the ring buffer is currently empty. More... | |
| LIBCOM_API int epicsStdCall | epicsRingBytesIsFull (epicsRingBytesId id) |
| Test if the ring buffer is currently full. More... | |
| LIBCOM_API int epicsStdCall | epicsRingBytesHighWaterMark (epicsRingBytesIdConst id) |
| See how full a ring buffer has been since it was last checked. More... | |
| LIBCOM_API void epicsStdCall | epicsRingBytesResetHighWaterMark (epicsRingBytesId id) |
| Reset the Highwater mark of the ring buffer. More... | |
EpicsRingBytes provides a C API for creating and using ring buffers (first in first out circular buffers) that store bytes. The unlocked variant is designed so that one writer thread and one reader thread can access the ring simultaneously without requiring mutual exclusion. The locked variant uses an epicsSpinLock, and works with any numbers of writer and reader threads.
Definition in file epicsRingBytes.h.
| LIBCOM_API epicsRingBytesId epicsStdCall epicsRingBytesCreate | ( | int | nbytes | ) |
| nbytes | Size of ring buffer to create |
| LIBCOM_API epicsRingBytesId epicsStdCall epicsRingBytesLockedCreate | ( | int | nbytes | ) |
| LIBCOM_API void epicsStdCall epicsRingBytesDelete | ( | epicsRingBytesId | id | ) |
| id | RingbufferID returned by epicsRingBytesCreate() |
| LIBCOM_API int epicsStdCall epicsRingBytesGet | ( | epicsRingBytesId | id, |
| char * | value, | ||
| int | nbytes | ||
| value | Where to put the data fetched from the buffer |
| nbytes | Maximum number of bytes to get |
| LIBCOM_API int epicsStdCall epicsRingBytesPut | ( | epicsRingBytesId | id, |
| int | nbytes | ||
| value | Source of the data to be put into the buffer |
| nbytes | How many bytes to put |
| LIBCOM_API void epicsStdCall epicsRingBytesFlush | ( | epicsRingBytesId | id | ) |
| LIBCOM_API int epicsStdCall epicsRingBytesFreeBytes | ( | epicsRingBytesId | id | ) |
| LIBCOM_API int epicsStdCall epicsRingBytesUsedBytes | ( | epicsRingBytesId | id | ) |
| LIBCOM_API int epicsStdCall epicsRingBytesSize | ( | epicsRingBytesId | id | ) |
| LIBCOM_API int epicsStdCall epicsRingBytesIsEmpty | ( | epicsRingBytesId | id | ) |
| LIBCOM_API int epicsStdCall epicsRingBytesIsFull | ( | epicsRingBytesId | id | ) |
| LIBCOM_API int epicsStdCall epicsRingBytesHighWaterMark | ( | epicsRingBytesIdConst | id | ) |
Returns the maximum amount of data the ring buffer has held in bytes since the water mark was last reset. A new ring buffer starts with a water mark of 0.
| LIBCOM_API void epicsStdCall epicsRingBytesResetHighWaterMark | ( | epicsRingBytesId | id | ) |
The Highwater mark will be set to the current usage
1.8.5
