EPICS Base  7.0.6.1
Functions
epicsSignal.h File Reference
OS-independent routines for ignoring Posix signals. More...
#include "libComAPI.h"
Include dependency graph for epicsSignal.h:
Functions
LIBCOM_API void epicsStdCall epicsSignalInstallSigHupIgnore (void)
LIBCOM_API void epicsStdCall epicsSignalInstallSigPipeIgnore (void)
LIBCOM_API void epicsStdCall epicsSignalInstallSigAlarmIgnore (void)
LIBCOM_API void epicsStdCall epicsSignalRaiseSigAlarm (struct epicsThreadOSD *)
Detailed Description
The requests in this interface are typically ignored on OS that do not implement POSIX signals.
Definition in file epicsSignal.h.
Function Documentation
LIBCOM_API void epicsStdCall epicsSignalInstallSigHupIgnore ( void  )
Ignore the SIGHUP signal. Required to avoid problems with soft IOCs getting SIGHUPs when a Channel Access client disconnects
LIBCOM_API void epicsStdCall epicsSignalInstallSigPipeIgnore ( void  )
Ignore the SIGPIPE signal. Required to avoid terminating a process which is blocking in a socket send() call when the SIGPIPE signal is generated by the OS.
LIBCOM_API void epicsStdCall epicsSignalInstallSigAlarmIgnore ( void  )
Ignore the SIGALRM signal. Required only if shutdown() and close() do not interrupt a thread blocking in a socket system call
LIBCOM_API void epicsStdCall epicsSignalRaiseSigAlarm ( struct epicsThreadOSD *  )
Raise a SIGALRM signal to a specific epicsThread
